BT Device Expert | Dan O | |
Did you get the help you needed? Help others by clicking on ‘Mark as accepted solution’ | Show your appreciation! Click on the thumbs up next to a reply to say thanks | Help guide to using the community? Click below |
I am a BT Employee and an expert on BT Devices queries. I am here volunteering my own time to give advice, and help where I can with BT device queries. Go here for more info. |
That's great to hear thanks. Is there any chance in the future to be able to manually connect each disc to the closest one, rather than auto selcting as it does have a tendancy to connect ot the wrong one in the chain.
Thanks a lot for the quick response by the way
OK so i've updated today and it seems to have made no difference. The discs just keep connecting to weaker one's and not the closest.
My setup with 6 discs should be fine and only connect to the one's closest but sometimes, it skips to the next one or two in the chain causing amber discs, which I just don't understand.
Why can't those of us that want to have the ability to manually and perminently associate one disc with another? I understand what your trying to achieve and certainly there is a place for an easy setup, but I for one would like the ability to manage my own system
