inixon79
Newbie
Message 1 of 2
BT wifi booster with HH6
Hi, Hope you can help me please?
I have the new HH6 and the wifi couldnt get down to the bedroom reliably.  Only living in a bungalow so nothing fancy big or anything.
But purchased a BT wifi booster and plugged in bedroom which receives the wifi brilliantly from the HH6 and then it boosts the wifi to full bars so well happy.
Now what my concern is that when I go down to bedroom, it stays joined to the HH6?  Thought that if the booster was a stronger signal it would jump across, the same being that when you leave the bedroom and go nearer the HH6 it should jump back?
Its not a problem that when I go into bedroom I just then select the booster ssid but its annoying that when you leave the bedroom and are half way between it drops and then no internet but hasnt rejoined the HH6 its still using the BT booster?
Can someone please help me.
Ian
1 REPLY 1
Message 2 of 2
Re: BT wifi booster with HH6
You will not get a seamless transfer from one network to another.
If its just a wireless repeater, then that can cause issues with some devices, Which BT wifi device did you buy?
