Message 1 of 10
BT1700 problem
Hi, new to here hope someone can help, so here goes,
My neighbour was bought a set of BT1700 cordless phones, on setting up followed instructions to remove call blocking etc, phone receives calls but does not ring, plug his old phone back in, rings ok. Plug his BT1700 phone into my line, rings ok, plug my BT2500 phone into his line, rings ok, has got the latest BT nte fitted, there are no extensions fitted, lead-in direct into nte, no adsl filters.
9 REPLIES 9
Message 2 of 10
Re: BT1700 problem
Welcome to this user forum.
Who provides his phone service?
Message 3 of 10
Re: BT1700 problem
Openreach
Message 4 of 10
Re: BT1700 problem
@Barney58 wrote:
Openreach
I meant, who does he pay his line rental to?
Does he have Caller Display enabled on his line?
Message 5 of 10
Re: BT1700 problem
BT are his service provider, on caller display on his phone
Message 6 of 10
Re: BT1700 problem
Then I would suspect that Caller Display is not working, and call blocking is still turned on. See page 27 on the online manual. Does his other phone have Caller Display, and is the incoming number showing?
It works at your house because Caller Display is most likely working at your house.
Message 7 of 10
Re: BT1700 problem
Ok, l’ll check later, cheers
Message 8 of 10
Re: BT1700 problem
Thinking about it, on the offending phone a call is displayed as an incoming call and you can still pick the call up
Message 9 of 10
Re: BT1700 problem
Then Caller Display is not working on their line, as it should display the caller`s number.
Is the facility switched on?
If you've ordered Caller Display check it's switched on by entering the code * # 234 #.
If it's active you'll get the message Caller identity will be displayed. If the facility isn't active then activate it using the code * 234 #.
Message 10 of 10
Re: BT1700 problem
I’ll check later
