Message 1 of 5
BT4600 Doesn't recognise when I pick up the handset off the cradle.
BT4600 Twin. Doesn't stop ringing when I pick up an incoming call. I have to press the Green Button to speak/hear. Same for both handsets. It doesn't seem to know I've picked up.
Have I somehow changed a preference or menu option?
4 REPLIES 4
Message 2 of 5
Re: BT4600 Doesn't recognise when I pick up the handset off the cradle.
@mike33
Page 31 in the manual.
Message 3 of 5
Thank You. I'll give it a go when I get home later. Cheers!
Message 4 of 5
Hi @mike33, did you get a chance to test this when you got home, and did you get it sorted?
cheers
John
Message 5 of 5
It's actually the phone of my rather tech non-savvy father (of 87) and yes apparently that is the issue and looks to be the correct 'fix' which I shall do when I see him next.
Many Thanks!
Mike
