StuartBarnes68
Message 1 of 3
BT4600 Premium Call Problem
My BT4600 Premium Nuisance Blocker telephone will let me make calls but doesn’t receive any calls - incoming calls ‘cut off’ before ringing but register as a ‘missed call’ on my handset ... help!
2 REPLIES 2
Andy005
Recognised Expert
Message 2 of 3
Re: BT4600 Premium Call Problem
Have you tried turning Call Blocking off to see if will allow all calls through?
Also check that there isn't any Call Divert active.
I think that you might have to reset the base unit back to factory settings, accessed through the Settings Menu.
StuartBarnes68
Message 3 of 3
Thanks, reset base and handsets ... hasn’t worked so think I’ve got a faulty unit which I’ll need to return and swap.
