GuyL
Message 1 of 2
BT4600 Volume
I’ve just bought a BT4600 for my aged, hard of hearing, parents as all the reviews say that the volume is good and significantly improved by the amplify button. I’ve just set it up and whilst the volume increase buttons make a very small difference, I would not describe it as loud even at maximum level 5. As far as I can tell the amplify button makes very little difference and it’s certainly not loud enough for my parents to hear even with hearing aids. They can just about get by with the external speaker turned on, but that’s not adequate.
Have I done something wrong in setup or are there any resolutions and ways of getting the ‘really loud’ (30db claim) activated so the phone does what it says on the tin?
1 REPLY 1
JohnC2
Moderator
Moderator
Message 2 of 2
Re: BT4600 Volume
Hi GuyL I'm sure you have completed the set up correctly. However, it's best to be sure so give contact the Product Helpdesk and they will be able to provide you with some guidance on what to check to ensure you are getting the best from the phone.
cheers
John
