Message 1 of 3
BT4600 phonebook transfer
Today I received a new BT4600 phone (3 handsets) and it is currently charging the batteries. It will replace our BT8500 and I was wondering if there is a convenient way to transfer the contacts stored on the BT8500 to the new BT4600. For example by registering the handset of the BT8500 to the base of the BT4600, or registering a BT4600 handset to the base of the 8500. Would this work?
2 REPLIES 2
Message 2 of 3
Re: BT4600 phonebook transfer
Hi @Zeewier, welcome to the forum, and thanks for your post.
I've had a look at the user guide on the BT4600 Help Page and can't see a way to transfer your contacts over.
cheers
John
Message 3 of 3
Thanks, yes I was afraid it wouldn't be possible but I was hoping somebody knew of an undocumented way to do the transfer automatically. I will now have to sit down for the next few hours and transfer my contacts manually... Thanks again for your reply.
