Message 1 of 5
Hi all my elderly mother has a bt4600 phone set up, after a power cut the main phone is flashing "C" on the screen and nothing in manual shows how to clear this. Phone works fine but looking at how to clear the screen. Any help appreciated
4 REPLIES 4
Message 2 of 5
Re: BT4600
@Paul36
Turn the power off on the base unit for about two minutes, then turn it on again. That should re-initialise the link.
Short power interruptions can cause the system to lock up.
You may get a message asking whether you want to change the time, but just say no.
Message 3 of 5
Re: BT4600
Thank you very much for swift reply
Message 4 of 5
Re: BT4600
This means the clock needs to be set again. That is why.
Message 5 of 5
Re: BT4600
You seem to have a habit of replying to 2 year old threads.
