Sh75
Message 1 of 4
BT6510 calls list function not working
I'm hoping someone can help with an issue that has arisen with my bt6510 handset. Up until 3 weeks ago the phone would show a list of who had called and the time using the calls list function. But now when you go to calls list all the numbers in the list are 000000000000 with a time of 0.00am.
The manual only says you must subscribe to a caller display service for this feature but sheds no further light on the issue. Our package with the network provider has not changed for months so I don't believe that can be the problem and when incoming calls come in the details are shown on the handset.
Can anyone shed any light on this issue please.
3 REPLIES 3
Keith_Beddoe
Message 2 of 4
Re: BT6510 calls list function not working
@Sh75
Have you tried turning off the power to the base unit for about a minute?
If its just one handset causing the problem, then take out the batteries for a couple of minutes as well.
Who provides your phone service?
Sh75
Message 3 of 4
Thanks Keith. Turning off the base unit did the trick. Brilliant
Keith_Beddoe
Message 4 of 4
Excellent 😀
Sometimes the communications between the base and handsets gets corrupted, so a power cycle resets it.
