Jools2
Message 1 of 6
BT8500 phone
I pay for caller display but for whatever reason when I click on calls it says not currently available, I have reset the base and I have reset the handset to no avail any ideas please
5 REPLIES 5
Keith_Beddoe
Message 2 of 6
Re: BT8500 phone
Caller Display check it's switched on by entering the code * # 234 #. If it's active you'll get the message Caller identity will be displayed
Jools2
Message 3 of 6
Re: BT8500 phone
nope the code you told me to put in just stays on the screen 😞
Keith_Beddoe
Message 4 of 6
Re: BT8500 phone
You need to call it, press the call button after you have input the code.
Jools2
Message 5 of 6
Re: BT8500 phone
it says callers identity will be displayed, please hang uo so I go to the calls and nothing, I have to say since posting I have contacted my phone comapny to see if there is something wrong, they are going to run a fault line check because they say it is showing as working, but because all 3 of my phones arent caller displaying there may be a line fault thankyou for your help
Keith_Beddoe
Message 6 of 6
Re: BT8500 phone
I would agree, you have a line or exchange fault.
