Message 1 of 7
BT8600 Blocked Calls List
Good afternoon,
As title, how do I display a list of the numbers I've blocked, please?
Sorry if this is obvious, but I'm very ancient!
Thank you.
6 REPLIES 6
Message 2 of 7
Re: BT8600 Blocked Calls List
Unfortunately, you can't.
Message 3 of 7
Thanks, so how do I unblock a number if I don't know what it is!
Message 4 of 7
You either have to temporarily turn off call blocking or add the number to the Allowed list (that you also can't view!).
Message 5 of 7
Thanks again.
It all sounds rather crazy!
Message 6 of 7
@WorriedParent
On my BT4600 which is similar, you can look at the incoming call log and it shows "blocked" against any blocked entry. You can then edit the entry and unblock it by adding it to your phone directory.
Message 7 of 7
Thanks, Keith, it's a bit complicated, but the number I want to unblock is from last year and so is no longer on the incoming calls list!
