stephanieo
Message 1 of 3
BT8610 answer phone
I want to set the phone so it does not ring and goes straight to answer phone between 4pm and 1pm the next day. I can't see  how to do this - auto on/off doesn't appear to work (maybe because the second time is earlier than the first?). Also, if we ignore the phone to make it go to ansaphone, as we are currently doing, how do I stop the base broadcasting the outgoing message and any message being left? Thanks.
2 REPLIES 2
JohnC2
Moderator
Moderator
Message 2 of 3
Re: BT8610 answer phone
Hi @stephanieo Welcome to the forum and thanks for your post.
Check out the user guide at BT8610 Advanced Call Blocker and if you can't find the answer to your problem you can call or email the product helpdesk for assistance.
Cheers
John
stephanieo
Message 3 of 3
Thank you - I had obviously read the guide end to end before posting here. I will try the helpdesk, thanks.
