Graeme60
Message 241 of 242
Re: BTHub6 (Smart Hub) As WiFi Extender or AP (Access Point) & HH5.
Maybe not disabling WiFi as it wouldn’t then connect to the HH6 in the garden room…….
Pink-Floyd
Message 242 of 242
Hi J
can you annotate your tutorial with master and servant to define the router and access router, respectively. I am getting confused as you you use hub for both. Many thanks.
