Iggy8285
Message 1 of 2
BTWH WiFi - All 5Ghz devices connected to primary disc
I currently have 22 devices connected to my Whole Home Wifi System through WiFi connection (4 discs)
  • 18 of them are connecting to the primary disc
  • 12 of the 18 above are all the 5Ghz devices in my home
  • 9 of the 18 devices above (both 2.4ghz & 5ghz) are located in very close proximity to other discs.
All discs have excellent connection to eachother.  So I have 2 questions:
  1. Is it normal for all 5Ghz devices to connect to the primary disc, regardless of proximity to another disc?
  2. Is there a way to control which devices (i.e. not portable, fixed locations) connect to which disc?
1 REPLY 1
lnajr02
Recognised Expert
Message 2 of 2
Re: BTWH WiFi - All 5Ghz devices connected to primary disc
1. Devices connect to the whole home system depending on a number of factors. Number of hope between discs and master disc signal strength and best channel to get best performance number of other devices I belive. This may not be the nearest disc.
2. Can you fix a device to a disc . Currently NO
