Aditi4
Newbie
Message 1 of 3
Baby monitor 6000
Hi How much can the camera pan? Will it do 180 degrees?
2 REPLIES 2
Moderator
Moderator
Message 2 of 3
Re: Baby monitor 6000
Hi @Aditi4,
It can go to 270 deg (135 deg each side left and right) Smiley Very Happy
DanielS
Community ModeratorDannyS
Show your appreciation!
Kudos”Kudos”
Lorne1056
Message 3 of 3
How much does it tilt? Mine tilts very little. Is this a fault?
