vickyvn
Newbie
Message 1 of 5
Baby monitor
Hi,
I have a bt 250 baby monitor, please could you let me know how to link the parent and baby units? I had to buy a new parent unit after the screen stopped working so the two no longer link.
Many thanks
4 REPLIES 4
BT Devices Expert
BT Devices Expert
Message 2 of 5
Re: Baby monitor
Hi @vickyvn, if you've misplaced the user guide, you can download it again on the product help page here: http://bt.custhelp.com/app/answers/detail/a_id/31742/~/bt-baby-monitor-250 or direct link to the PDF  here.
I think the instructions you need are on page 15.
Hope this helps.
Device expertBrunoN
Show your appreciation!
Kudos”Kudos”
vickyvn
Newbie
Message 3 of 5
Re: Baby monitor
Thanks, but that only shows how to turn on 2 units that are already linked, not how to link a new unit
BT Devices Expert
BT Devices Expert
Message 4 of 5
Re: Baby monitor
Hi again, sorry for the delay.
I checked with the actual expert on this specific product. The parent and baby units are paired in the factory. You can't mix and match and link units from different sets.
All I can suggest, assuming you got this 2nd hand (product has been discontinued by BT a few years ago), can you go back to the seller to see if they have the other unit?
Device expertBrunoN
Kudos”Kudos”
vickyvn
Newbie
Message 5 of 5
Re: Baby monitor
Oh that's a shame - I've paired a second hand BT 350 monitor before so I thought you could do it with the 250. Thanks anyway
