Message 1 of 3
Black disc
I have a BT Smart Hub 2 at one end of my house and a Black disc at the other. Can I add a further black disc in the garage (at the end of the house furthest from the Hub) that will connect to black disc 1 and give me wifi in the garage?
2 REPLIES 2
Anonymous
Not applicable
Message 2 of 3
Re: Black disc
You can have up to 3 black discs. Whether they will work as you want them to depends on the signal strength where you wish to place them
Message 3 of 3
Re: Black disc
Hi @SueAntrobus, welcome to the community and thanks for posting, if you have the complete wifi service I'd recommend running diagnostics in the MyBT app. It will pick up if there are any wifi weakspots in you're home. If you then get in touch with 0800 800 150 and ask to speak with the broadband faults team they'll be able to organise you an additional disc to improve the coverage. You can repeat this process again if a further disc is needed.
Neil
