Message 1 of 2
Blocking Devices
Quick question
if I block a device from from my Whole Home mini discs, can I then connect that device straight to my Wi-Fi hub
1 REPLY 1
BT Devices Expert
BT Devices Expert
Message 2 of 2
Re: Blocking Devices
Yes, blocking a device on Whole Home Wi-Fi doesn't affect the Hub. If you don't want it to connect you will need to disable Wi-Fi on the Hub.
Dan-O
