Keith_Beddoe
Message 11 of 31
Re: Brand new Smarthub 2 will not accept default password
Perhaps the Alexa devices are trying to connect to BTWifi/FON, which would be classed as a public unsecured network?
gg30340
Message 12 of 31
Have you turned off "smart set up" since you have carried out the factory reset of the hub. If not you should do that. It can cause problems with some devices.
grajay
Message 13 of 31
Definitely was connecting - or trying - to the hub itself - not the BTWiFi/FON.
Graham
grajay
Message 14 of 31
That is the next thing I'm going to try - I now have both routers on my desktop one on and one off and I switch them back and forth when I test the new hub.
Graham
imjolly
Message 15 of 31
no sure what you mean by switching routers on and off but constantly disconnecting your internet connection will cause a problem with your connection and more than likely a reduction in connection speed
grajay
Message 16 of 31
Yup - sorry I meant that I have both routers powered up and switch over the cables to see if I can solve the problems.  Usually I'm just swapping the broadband cable.
Graham
imjolly
Message 17 of 31
that's what I thought you meant - that will cause a drop in your internet connection as you change hubs and done often will cause DLM to see as line is unstable and take action by increasing noise margin and reducing connection speed
grajay
Message 18 of 31
Great - one just cannot win.  Think I'll just dump the Smarthub!
Graham
licquorice
Message 19 of 31
If both routers are powered up you will be transmitting wifi signals from both regardless of where the broadband is connected.
grajay
Message 20 of 31
I don't understand how a powered up hub but not connected to the broadband cable will be transmitting a wifi signal - but if you say it does then who am I to disagree?
Meanwhile this UnsmartHub and it's disc friend is going in the bin, and good riddance to them both
Graham
