Magna1016
Message 1 of 5
Broadband cable for Smart Hub 2 from filter to hub
Just received our Smart Hub 2 to replace the existing Smart Hub. Unfortunately the existing cable from the filter to the Smart Hub 2 does not fit into the hub as wrong size. What cable do I need or do I need to get a new filter and cable
4 REPLIES 4
Keith_Beddoe
Message 2 of 5
Re: Broadband cable for Smart Hub 2 from filter to hub
@Magna1016
It should fit into the DSL socket. Although it looks bigger, its designed to take both RJ45 and RJ11. Take a closer look.
I am surprised that you did not get an extra RJ11 lead, but perhaps BT are not sending them out.
imjolly
Message 3 of 5
if you are using a standard rj11 cable for existing hub the the cable should fit the new SH2 as connection as the same
Magna1016
Message 4 of 5
You are correct that the socket in the back of the new Smart Hub 2 does look bigger but maybe an optical elusion - I will give it a try but if the existing cable attachment is too small what cable do I need and what filter do I need
licquorice
Message 5 of 5
It will fit.
