xsi303
Message 1 of 2
Broadband extender flex 600 kit
Hi
I've just bought the 600 flex kit and already have a wifi home hotspot 500 kit (I was told they were comparable in the shop)
Firstly the 600's wouldn't connect to the 500 (plugged into the router) so I swapped that for one of the 600's the wifi 500 unit works fine upstairs but after a while the second 600 in the living room stopped working and won't re-connect now
Any help would be greatly appreciated
1 REPLY 1
flamethrower
Message 2 of 2
Re: Broadband extender flex 600 kit
Hi xsi303
On paper these device are compatible:
 https://www.shop.bt.com/content/uni2/documentation/9n14/mini-wi-fi-home-hotspot-500-kit-spec.pdf
 https://www.shop.bt.com/content/uni2/documentation/bvfh/mini_wi-fi_home_hotspot_600_multi_kit_spec_s...
They should work together. The FAQ is here and doesn't suggest any inter-op issues:
 http://btsupport.custhelp.com/app/answers/list/c/7187
Is the configuration tool able to see the stopped unit at all?
Does the tool have any option to update the firmware on the devices?
I'd try a factory reset on all the units and start again. Failing that contacting BT directly.
