Dpking
Message 1 of 5
Broadband extender unidentified networks
I have 2 broadband extenders which have worked OK for more than a year, one  connected to a laptop and 1 to a smart tv. they have just stopped working and though the data light is showing on the extenders, the laptop gives an unidentified network error.
I have reset the hub but this hasn't made a difference. if I connect laptop by Ethernet cable directly into to the hub it connects to network OK. I don't know what else to try.
4 REPLIES 4
Message 2 of 5
Re: Broadband extender unidentified networks
@Dpking
Are both remote ends slaved to the single master unit connected to the home hub, as you can only have one master connected to the home hub, the rest have to be slaved of that one master.
Did you do a full factory reset of the home hub?
MorgaineD
Expert
Message 3 of 5
Presumably it's possible to do a hub Save, then the Factory Reset, and then a Restore to get the settings back, right?
Dpking
Message 4 of 5
A full reset appears to have resolved the issue. thanks
Message 5 of 5
Good, its just one of those issues that are common with the home hubs.
