Message 1 of 9
Broadband fibre optic modem.
Hi, can you tell me where I can get a fibre optic modem on Bt website ? I’m using google WiFi as the router. Many thanks Tim.
8 REPLIES 8
Message 2 of 9
Re: Broadband fibre optic modem.
Don't understand the question. You can only get a fibre modem(ONT) by ordering an FTTP service if it is available to you.
If you are currently using a router, what broadband service do you have and how is it currently connected?
Message 3 of 9
Hi,
I’m  using BT super fast broadband and the provided WiFi router. Thing  is I want to use my google WiFi  in conjunction with a modem. I’m not using FFTP.
Cheers.
Message 4 of 9
Then your options are quite limited. Either a second hand Huawei HG612 Openreach modem from ebay or a Draytek Vigor 130 or 166 modem from the usual sources. There are also various Zyxel modem/routers that can be configured in bridge mode. There is nothing you can purchase from BT.
Message 5 of 9
Ok. Thanks for helping out. I’ll have a look on eBay.
Cheers, Tim.
Message 6 of 9
The confusion was 'fibre optic modem'. It's not a fibre modem you need, it is a VDSL modem.
Message 7 of 9
So the huawei modem , does it use  DSL line for fibre optic ? That’s all I can see from pics.
Message 8 of 9
Cool I’ll look into vdsl modems
Message 9 of 9
Yes, you haven't got fibre. The only fibre is to the green cabinet, not your house unless you FTTP.
