6golfview
Message 1 of 3
Bt Mini Hub wired solution
i am trying to get wifi into a games room under a garage, detached from house.
The walls are very thick and it is on a separate electrical circuit so traditional extenders wont work.
Can I run an ethernet cable from the main hub into the back of a mini hub so that it will transmit wifi into that area ?
2 REPLIES 2
Message 2 of 3
Re: Bt Mini Hub wired solution
Yes, or just run an Ethernet cable to any wireless access point (WAP) TP-Link ones are reasonably priced.
6golfview
Message 3 of 3
Perfect, thanks for the help, saved me £70 👍🏻
