ryanwoods10
Message 1 of 4
Bt Whole Home queries
Hello, a couple of questions regarding the whole home. Trying to simplify the WiFi at my local football club. Firstly, we have issue with speed down there, I'm sure I've read somewhere that if a guest network is enabled it will throttle the bandwidth to about 20% so devices on the main network effectively get priority. Is this correct? Also with regards to the Ethernet ports on the back can I use this as an ethernet connection into a device/could I plug it into a switch to get an additional ethernet port?
3 REPLIES 3
DanielS
Moderator
Moderator
Message 2 of 4
Re: Bt Whole Home queries
Hi @ryanwoods10,
Take a look at the following thread:
BT Whole Home v1.02.03 build03 guest network
Our TV expert @Dan-O confirms that the guest networks Guest Wi-Fi bandwidth is set at 20%.
I noticed you mentioned that your local football club has speed issues. Do they have a residential BT Broadband service or a BT Business Broadband service? I only ask as I may be able to point you in the right direction for support.
DanielS
ryanwoods10
Message 3 of 4
I would think it's business but not entirely sure. The speed will be because of its location as it is no where near anything and therefore not expecting the infrastructure to be upgraded any time soon. That's the reason the speed throttling is actually a huge bonus so the nessacery devices get priority. That's why I'm wondering if I can add a switch to one of the Ethernet ports on the disk so that everything can be managed through the whole home.
Steve59
Message 4 of 4
Yes you could add a switch as it is just a 1ghz port
