mrtilly
Message 1 of 4
Bt adaptor
Hi I'm looking for a BT adaptor for BT 8500 phone part number 066270 I can't find it in the bt shop.  There are some on Ebay however I want to make sure it's safe. Anyone recomend were I can purchase one.
3 REPLIES 3
Message 2 of 4
Re: Bt adaptor
Try Discomm who are BT's partner for refurbished products. Even if the product doesn't appear on their website, give them a call as sometimes they have spare
mrtilly
Message 3 of 4
Re: Bt adaptor
Thanks,  however it was out of stock so bought twin phone pack from ebay 2nd hand but the price was good.
Moderator
Moderator
Message 4 of 4
Re: Bt adaptor
Hi @mrtilly  and welcome back.
It sounds like you managed to get this sorted but thanks for posting and updating the thread. I'll mark it as resolved but if you have any other questions please post back. There's always someone around to help.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
