Bryansmith85
Message 1 of 6
Bt range extender plug
All my Internet andoing wifi is working. Had a tp link extender n tHoughton it was broke after being in use for 3 months. So I bought the bt one set that one up and it's doing the same thing ie all connected to the hub/router but then saying no Internet secured when it's all set up right ??
Tags (1)
5 REPLIES 5
Message 2 of 6
Re: Bt range extender plug
Welcome to this customer to customer forum @Bryansmith85
First thing is to do a factory reset on the home hub.
http://bt.custhelp.com/app/answers/detail/a_id/11386/%7E/how-do-i-reset-my-bt-hub-to-its-factory-set...
See if that helps.
Range extenders usually perform very poorly, compared with proper wireless hotspot devices.
Bryansmith85
Message 3 of 6
I've done that 20 times haha y I bought a new one thinking the first was broke as it had worked perfectly for months.
Bryansmith85
Message 4 of 6
It's all conected to the router perfectly just still no Internet secured
Message 5 of 6
Can you connect directly to the home hub wireless with the extender switched off?
Does a direct Ethernet cable connection work?
Bryansmith85
Message 6 of 6
Yes it all works without it
