Award90210
Message 1 of 22
Bt whole home WiFi allowing BT Fon
We recently bought the whole home WiFi tri pack and now it’s allowing anyone to connect via bt fon (for an hourly/daily fee) and its using our WiFi. How can I deactivate this? I’m sure BT have made it secure, but I just don’t want random neighbours being able to use our WiFi. Plus, we don’t have unlimited WiFi.
21 REPLIES 21
-Richie-
Guru
Message 2 of 22
Re: Bt whole home WiFi allowing BT Fon
It doesn't count towards your usage and has it's own capacity, so it won't slow you down either.
It's only accessible to BT broadband or BT wi-fi customers.
It can be disabled though if you wish.
Award90210
Message 3 of 22
Thanks For your quick response Richie.
Yeah, definitely don’t feel comfortable with it. How can it be removed?
gg30340
Message 4 of 22
See attched link. Be aware that it does not turn off right away and can take up to 30 days.
https://bt.custhelp.com/app/answers/detail/a_id/12958/~/how-do-i-opt-out-of-bt-wi-fi%3F
licquorice
Message 5 of 22
Also be aware that turning it off will mean that you lose the ability to make use of the free BT wifi whilst out and about.
Award90210
Message 6 of 22
But I don’t have a bt account. I bought the whole home WiFi triple pack and connected it to my virgin box (virgin is my service provider, not BT).
So for some reason, connecting the whole home WiFi (when not a bt customer) allows the devices to connect to bt fon for strangers.
Please advice ?
gg30340
Message 7 of 22
I don't have the device so I don't know the lay out but are you able to log onto or use the app to get to the management pages to see if there is an option to turn off BTWifi from there.
Award90210
Message 8 of 22
Hi - no, there is no option at all in any of the settings. In fact, it doesn’t tell you anywhere (on the website, box or included leaflet) about bt FON, which I think is a bit naughty, really.
licquorice
Message 9 of 22
Please advice ?
I don't see how that can work, there will be no network available for BT wifi. It may be broadcasting an SSID but it won't have any connectivity.
Keith_Beddoe
Message 10 of 22
There is supposed to be a guest network built in, but you should be able to turn it off.
Was this new, or secondhand?
If it was secondhand, the factory reset the system.
