Paul_31
Message 11 of 14
Re: Bt whole home WiFi
Maybe try the 'factory reset' of the discs I mentioned above? Worth a try.
Slsargeant
Message 12 of 14
I have and no joy 😩 thanks for your advice though, really appreciate it
BT Devices Expert
BT Devices Expert
Message 13 of 14
Hi @Slsargeant
Which router are you using to connect your Whole Home Wi-Fi discs? It's possible something is preventing the discs connecting to the Internet to check for updates. Have you tried to check a few times in case the server is busy?
Dan-O
Community ModeratorDanO
Show your appreciation!
Kudos”
I am a BT Employee and an expert on BT Devices queries. I am here volunteering my own time to give advice, and help where I can with BT device queries. Go here for more info.
Slsargeant
Message 14 of 14
Hi Dan, I tried all weekend. I have a 4G router, I have had 3 discs working perfect for 2 months and I just want to add 2 more to it but when I plugged in the new disc to the router I got a red light and then the firmware update message that won’t go away.
If I go on to the desktop version, it tells me that my firmware is the most current version.
