EricWalker93
Message 1 of 3
Call Blocker on BT1200 phone
Suddenly today my BT1200 phones, both of them will not accept incoming calls. My answerphone accepts them.  If I click MENU   it says 'Call Blocker'.    Also on bottom of screen is a hand with a 'no entry' sign.   My user guide says this means ''Block Call feature on'.   But my block list says 'empty'.   How can I turn off the Call Block feature?
2 REPLIES 2
Dean007
Recognised Expert
Message 2 of 3
Re: Call Blocker on BT1200 phone
Hi @EricWalker93
Have you tried ..
Entering the Call Block Menu
The Select Block Mode
Then Select Block BList Off
If you do not have a black list its pointless it being enabled.
See if this helps if not pop back and let us know...
EricWalker93
Message 3 of 3
Well, by a miracle, after about 3 hours it seems to have cured itself!  Hallelooyer!
