Message 1 of 9
Call Blocking problem
My BT8600 nuisance call blocker has worked fine until a few days ago. Now with an incoming call, I get the message to say the call is being announced. If I press 1 to accept the call, the line goes dead. If I then look at call history, there are two entries - one showing the number which called and a second entry showing 'No Number'.
Is my equipment faulty? How do I resolve this? As far as I can tell there is no problem with my line - no line noise.
8 REPLIES 8
Message 2 of 9
Re: Call Blocking problem
@rmblunden
Welcome to this user forum.
Who provides your phone service?
Have you made sure that caller display is still enabled on your phone line?
Message 3 of 9
Phone service is from John Lewis (Plusnet). Yes caller display is enabled, the number appears in my call list.
Message 4 of 9
Have you tried turning off the power to the base unit, for a couple of minutes?
Message 5 of 9
I'll give that a go. Thanks
Message 6 of 9
The base unit can lock up and give strange results, usually after a dip in the mains voltage, where the unit does not reset properly.
Message 7 of 9
Thanks again. I don't get many incoming calls, so it will be a while before I know if this has worked.
Message 8 of 9
Thanks again. It seems that rebooting my base unit has resolved the problem.
(And I've been promoted to a Newbie 😂)
Message 9 of 9
Excellent 😀
