Message 1 of 3
Can BT Whole Home be powered using Power over Ethernet POE?
As per the subject line, can BT Whole Home be powered using Power over Ethernet (POE). Obviously I intend using a wired backhaul.
Many thanks
Clive
2 REPLIES 2
BT Devices Expert
BT Devices Expert
Message 2 of 3
Re: Can BT Whole Home be powered using Power over Ethernet POE?
Hi,
Only the DC power supply can be used to power the discs at this time.
You can use the Ethernet port as a wired backhaul as you suggested but will also need to use the mains plug.
Dan-O
Message 3 of 3
Thanks Dan-O for your answer.
I have another (pre-purchase) question relating to BT Whole Home, which I will post later as a seperate item.
Cheers!
