Message 1 of 5
Can I give hub to someone else
Hi,
Last December I got sent out a new hub - the hub I had already was fairly new already but I was sent one out anyway which I am using now.
I have noticed on visiting my elderly mother that she has a very old bt hub (the REALLY old style white one, I have no idea why she has never had an upgrade) - can I give her my previously used hub to use? Or will it need to be reset etc.
Obviously if not I will ring BT for her as her connection is weak so I think she requires some kind of upgrade regardess but thought I'd see if this was an easier solution.
Thank you.
4 REPLIES 4
Message 2 of 5
Re: Can I give hub to someone else
If you had the old hub before December 2019 it is yours to do as you wish with.
Message 3 of 5
Thank you for the reply - yes, I believe I got it prior to Dec 2019. My worry is if it will actually physically work for her though - as in does it need to be reset etc? or should I be able to plug it in and all will be okay?
Apologies, I'm not the most technical person.
Tags (1)
Message 4 of 5
Just plug it in. Any WiFi devices will need to change to the new ID and password.
Message 5 of 5
Thank you very much
