Message 1 of 5
Can I use the BT Smart hub with the BT Whole Home WIFI?
I have a smart hub, but want to buy the whole home WiFi 3 pack, to reach a bit further.
But if I plug the whole home unit into the smart hub, won’t that make the smart hub pointless.
Ideally I would like the smart hub to be able
to connect with the While Home units without needing to use a cable.
Has anybody done this?
4 REPLIES 4
Message 2 of 5
Re: Can I use the BT Smart hub with the BT Whole Home WIFI?
You need the smart hub as a modem/router, the whole home wifi isn't a modem/router.
Message 3 of 5
Thanks, but do I need to plug them into each other? Or will be able to connect without a cable?
Message 4 of 5
I haven't got either a home hub or whole home wifi but I think the first disc needs to be connected via ethernet to the hub and the wifi on the hub turned off.
Message 5 of 5
