Message 1 of 4
Can a BT 4600 be mounted on a wall?
Want to mount the answerphone base unit on a wall.  Is there a bracket or ….?
3 REPLIES 3
Message 2 of 4
Re: Can a BT 4600 be mounted on a wall?
Message 3 of 4
If you must wall mount it you always could buy a small wall bracket and make a shelf for it to sit on.
Message 4 of 4
Thanks feared that would have to be the way to go!
