Albie4464
Message 1 of 4
Can one copy contacts from BT premium to BT Diverse 7110?
I have a BT Premium phone and have purchased a BT Diverse 7110 phone plus extra phone because I can use a headset due to my poor hearing
Is there any way to copy contacts from the former to the latter? or to print the contacts list?
Many thanks
Albie
3 REPLIES 3
NeilO
Moderator
Moderator
Message 2 of 4
Re: Can one copy contacts from BT premium to BT Diverse 7110?
Hi @Albie4464 welcome back to the community and thanks for posting, I'm sorry that's not possible.
There is a Bluetooth function on the BT Premium phone to sync mobile phone contacts over to the Premium phone, but I'm sorry that won't work with the Diverse handset.
The Contacts on the Diverse 7110 have to be manually entered by following the guidance on page 18 of the user manual.
Neil
Albie4464
Message 3 of 4
Thank you, that confirms my thoughts
Albie
NeilO
Moderator
Moderator
Message 4 of 4
@Albie4464 No worries, you know where we are if you've any further questions.
Neil
