Hi I Have BT Router 4.0 And I Can't Can't Change Name Password OR ANything Bcz I Cant Login To 192.168.1.254 Help Me Out Pls
Press the recessed button on back and holding until lights flash about 20/30secs and then the password on hub should now work
If you have a VPN service running, disable it to access 192.168.1.254.
If Windows 10.
Open Settings
Click Network & Internet
Click the Properties button for you connection
Make sure the connection has been correctly identified as Private.
