fixit9660
Message 1 of 18
Can't change new Smart Hub 2 SSID or Wireless Password
Two days ago I got my BT Fibre Broadband service. I've got a Smart Hub 2.
I can't change either the SSID or Wifi Password. The screen accepts my changes and asks me if I'm sure. I click on Yes, and Save. The screen shows my changes in the appropriate boxes but if I navigate away from that page and go back the changes have been replaced by the original/default configuration.
Firmware version:v0.21.03.07094-BT. It ws Updated Wed Nov 18 12:03:53 2020. I'm running Win & Pro 64 Bit and the latest Firefox Browser.
17 REPLIES 17
imjolly
Message 2 of 18
Re: Can't change new Smart Hub 2 SSID or Wireless Password
are you using just letters/numbers or are you using characters as well  some characters may not be acceptable and no spaces
fixit9660
Message 3 of 18
The SSID is Upper and Lower Case letters interspersed with hyphens.
The Wifi Password is all Lower Case letters interspersed with hyphens. I realise that from a Security viewpoint this isn't "best practice" but I just want to restore service to about 30 devices while I arrange to reconfigure them all at a convenient time.
imjolly
Message 4 of 18
I have used hyphen is SSID so it accepts that now sure about more than 1
fixit9660
Message 5 of 18
I've just discovered that it will accept the new SSID, if I change that only. It won't accept the new Wifi Password. I have tried multiple password combinations of upper and lower case and numbers, with and without hypens. Nothing seems to work there.
BAFlyer
Message 6 of 18
I had the same issue and found that if I changed the password via the  BT app, it worked, try That.
fixit9660
Message 7 of 18
Via the BT App? Really! Hmm, now who do I know that has a smartphone....
fixit9660
Message 8 of 18
<sigh> why is nothing easy? OK...which BT App is it, specifically please? I went to the Google Play Store and search for BT app and had a load of BT Plc Group Apps listed, and after a lot of wasted time, none of them are apparently the correct one.
Is this just a web browser issue? I'm using firefox. If the app works but the browser doesn't...
BAFlyer
Message 9 of 18
The app is called My BT.  You’ll need to login in with your BT account username and password.  I'm not sure but assume the password issue is a bug in the Smart Hub firmware as I tried several browsers and could not change the password.  It may be that the firmware will not accept an old style ‘simpler’ password but I nearly gave up and trying the My BT app option was a last resort.  Fortunately it worked as  I was not looking forward to changing the password on all my Wi-Fi devices!
fixit9660
Message 10 of 18
..."Your device is not compatible with this app."...
Well thank you for your efforts anyway @BAFlyer , I do appreciate them.
Anyone else got any suggestions please?
