Nten
Newbie
Message 1 of 2
Can’t get a network response in initial setup
Maybe I’m the only one that’s had this problem, but I can’t get past the step testing the network connection.
The backstory- I’ve purchased the 3 disc system, taken the first disc out and powered up and plugged in. Indicator light is blue, password is typed in correctly, but I consistently get the error “There was no response from your network”. I’ve tried powering down the system and restarting, but no luck. Any help would be greatly appreciated.
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Can’t get a network response in initial setup
Hi @Nten Sorry you are getting this error with your Whole Home Wifi set up.
Please contact the product helpdesk on phone: 0808 100 6116 Mon-Fri 9.00am to 5.30pm and Sat 9.00am to 2.00pm or by email btconnectedhome@bt.com and they will be able to help you.
Cheers
John
