Message 1 of 15
Can't port forward
Hello, I am trying to port forward my Minecraft server on my BT Smart Hub 2, but when I port forward, UpNp is unchecked and yougetthesignal.com says the ports are still closed.
 All help appreciated, thanks!
14 REPLIES 14
Anonymous
Not applicable
Message 2 of 15
Re: Can't port forward
Have you allocated the rule to a device / IP Address?
Message 3 of 15
Message 4 of 15
Can't port forward
Hello, I am trying to port forward my Minecraft server on my BT Smart Hub 2, but when I port forward, UpNp is unchecked and yougetthesignal.com says the ports are still closed.Screenshot 2021-01-10 201310.png
Screenshot 2021-01-10 201427.pngAll help appreciated, thanks!
Message 5 of 15
Please don't post the same question in multiple places, it just causes confusion.
Message 6 of 15
What does https://www.grc.com/shieldsup show. The minecraft server needs to be running for the port to open.
Message 7 of 15
Message 8 of 15
Well there you go
Message 9 of 15
my friend still can't join
Message 10 of 15
Then that's a problem with your application not port forwarding.
