Hi all
i would be really grateful for your help. I had a home hub 6 which was connected to my Cctv via devolo plug and I used to be able to access through the wireless network when at home and externally through the set up of a dynamic dns site through no-is.com. This was all working fine. I have now installed the whole home premium wi fi but whilst I can still access the pictures internally I can’t access when I am out. I haven’t changed anything else and if I turn off the whole home it still doesn’t work. I have checked port forwarding and I have those set up on the router still and the only thing that changes was BT cane out to look at my master socket as there was a line fault. They removed some star cabling wire so I only have one socket now. This is fine but I cannot work out how to get the Cctv externally again. Please could someone help?
