Message 1 of 2
Change Delivery Address of Broadband Hub
Hello!
I have just set up internet for a flat I am moving into. However, it seems the Smart Hub 2 will be delivered TWO DAYS BEFORE I actually pick up my keys to move in.
Given it is a block of flats, I don't think the mailbox would fit the smart hub 2 like the FAQ suggests, so I would much rather just have the box delivered elsewhere.
Is this possible??
Thanks!!!
1 REPLY 1
Message 2 of 2
Re: Change Delivery Address of Broadband Hub
You would need to contact BT Billing  0330.1234.150 and ask.
