chrisfoster1971
Message 1 of 2
Changing primary disc in 3 disc whole home query
I've not long had a three disc setup and I am experiencing a couple of issues.
1. Constant BT Whole home App ( Android ) Unable to connect with "You are not connected to your Whole Home Wi-Fi"
 It prompts to connect and eventually returns with "Can not connect to AP"
Now this may well be correct as the primary AP is actually the one that is in our detached garage some distance away and out of range of the house.
2. Is there any way to change the primary AP to one that is integral of the house?
1 REPLY 1
liamh
Message 2 of 2
Re: Changing primary disc in 3 disc whole home query
I have the same problem with "You are not connected to your Whole Home Wi-Fi" even though I am connected to the while home WiFi, and through to www... I'm using it to type this.
Same message as you when it fails to connect to the network it is already connected to...
Also on android.
