Misterviv
Newbie
Message 1 of 4
Charging BT everyday phone new base unit, query display code
Hi,
Just connected a new everyday base unit to charge handset, and display shows 'Power up B5', which is flashing. I can't find any mention of this display code in the leaflet or online. Is it charging OK, and is there a list of error messages and codes anywhere? Thanks in advance.
3 REPLIES 3
Message 2 of 4
Re: Charging BT everyday phone new base unit, query display code
Welcome to this user forum @Misterviv
It will be "Power up BS"   Power Up Base station.
Check that you have power to the base unit, and that the phone is making contact with the charging connections in the base unit. Perhaps its not seated correctly?
Misterviv
Newbie
Message 3 of 4
Thanks for that, the adaptor was not quite making contact with the extension. Duh. Appreciate the speedy response.
Message 4 of 4
No problem Smiley Happy
