mikewestmorland
Message 1 of 5
Compatibility BT Mini Hotspot Wi-fi
I have had a Hotspot 600 with a single slave unit for a couple of years.  I’ve now bought a refurbished set with 2 slave units, which works fine.  Can I use my original slave as a 3rd unit?  Obviously its wireless key is different from that of the 2 new slaves, but I assume that refers to the sender unit.  At the moment, my iPhone recognised the spare unit, but can’t get internet through it.
4 REPLIES 4
Keith_Beddoe
Message 2 of 5
Re: Compatibility BT Mini Hotspot Wi-fi
Les-Gibson
Recognised Expert
Message 3 of 5
Yes you can, see "How to add more Powerline extenders to your existing network" in the manual at
https://www.bt.com/content/dam/bt/help/legacy-ug/broadband-and-wi-fi-devices/3907%20Mini%20Wi-Fi%20H...
In short, this changes the network key to that of the network you wish to add to
♪♪I don't work for BT, I offer my time and help for free. If you'd like to leave a kudo, you may do so by clicking the rating button below.♪♪ 😄
mikewestmorland
Message 4 of 5
Worked fine. Many thanks.
mikewestmorland
Message 5 of 5
Sorted. Many thanks.
