Sulis
Message 1 of 5
Complete/Home Wi-fi
Is there a difference between the complete Wi-fi discs and the Home Wi-fi discs apart from  the colour?
I’m having fttp installled and Smart hub 2 will be delivered. I will definitely need 3 discs to cover the house. Complete Wi-fi comes with Smart hub 2 which I will already have. Should I just buy the white discs ?
4 REPLIES 4
VeteranISPUser
Recognised Expert
Message 2 of 5
Re: Complete/Home Wi-fi
Hi @Sulis   The Smart Hub 2 has been designed to use the Complete WiFi discs (black) as a seamless network. However they are expensive at £100 each
Sulis
Message 3 of 5
OK thanks for that. I guess I’ll get the Complete Wi-fi stuff and not use the extra router.
NeilO
Moderator
Moderator
Message 4 of 5
Hi @Sulis I can confirm that what @VeteranISPUser has advised is correct.  The Complete wifi service is designed to work with the Hub 2 as part of a mesh network where as the Whole home wifi wil work with any router but the routers wifi will not be part of the mesh network. The complete also wifi subscription comes with a guarantee to deliver a strong wi-fi signal in every room of your home.
Sulis
Message 5 of 5
Thank you for the explanation.
