I have just received by new Smart Hub 2 with its black Wifi disc. This is set up and working correctly. However, I also have, from my previous set up, three white BT Whole Home Wifi discs which I would like to integrate into the new (black) network.
I can't find any instructions on how to do this. Is it possble to associate the white disks with the black disk using WPS association and thereby use the white discs to extend the black network? Or is there some other process?
Solved! Go to Solution.
Welcome to this user forum.
The two systems are not compatible.
