I am interested in complete wifi, but would certainly only need one disc.
I could start a new 24 month contract at about £10 a month more than I am paying at the moment, meaning a total cost of about £240. Alternatively I could buy a disc for about £100, which would obviously be a lot cheaper. I have, therefore, two questions to help me decide,
1. If I buy a disc (new) from a non-BT retailer, will that be able to be set up in the usual way, and
2. When I look on line, some of the discs seem just to have "BT" on the front and some have "BT" and the colourful logo. Is there any distinction between them?
Solved! Go to Solution.
You can only use the black BT Complete Wifi discs, not the white BT Whole Home discs, if you want to connect via wireless to the BT Smart Hub 2.
BT sell the discs at about £100 each.
Keith
You are probably right about BT selling the discs, but at the moment searching for them on the BT shop doesn't find them.
@northshields wrote:
Keith
On this page https://www.bt.com/broadband/accessories/
As the ones provided by BT are only on loan, there are not going to be may secondhanded ones.
Keith,
Thank you for that. I was looking on the shop.bt.com site rather than the main BT site.
Hello @northshields @Keith_Beddoe
Did you purchase a wifi black disc from bt and did you get it to work with the business smart hub 2? Without starting any extra contract etc with BT?
John
JohnMcK,
No, I haven't gone for it yet, although I am sure that it would not mean starting a new contract.
I asked the question of BT - see web chat photos
initially looking as though they wanted me to take contract, then it changes,
so I asuming from this chat that as my full fibre to property is working fine I should be able to add a disc that I purchase myself onto the Business Home Hub2.
John
JohnMcK
I think you are right. The only thing you may need to check out is whether the black disc works with the Business Smart Hub as the web chat you had with BT doesn't seem to cover that point explicitly.
will check that - I had put it (ie Business smart hub 2) twice in fact in a question at the top of the chat but yes it got missed off in following replies
