Message 1 of 4
Complete Wifi Disc
Hi, wonder if any one can help.
Just got complete wifi with one black disc which I cannot connect to my smart hub.
I have an old bt hub  (downstairs) connected to my smart hub (upstairs) via ethernet which I use as a wifi access point at one end of my house.
When I try to connect the disc to my smart hub it does not let me. It does if I disconnect the old Bt hub. I want the disc to connect to my smart hub to improve the wifi upstairs without having to remove the old hub.
Would appreciate any ideas to solve this please.
3 REPLIES 3
Message 2 of 4
Re: Complete Wifi Disc
The black discs will only connect to the smarthub 2, it won't work with your older hub
Message 3 of 4
Hi @sami69   Replace the old Hub with another Complete WiFi Disc. If you subscribe to Complete WiFi they are loaned free.
Message 4 of 4
Thanks, will try that. Will have to get additional disc to improve the wifi upstairs.
I didn't think the old hub would interfere with trying to connect the disc to the smart hub. Can only connect to it if I disconnect the old hub from the smart hub.
