Johnph
Member
Message 1 of 1
Complete wifi
I have complete WiFi, smart hub 2 and 4 discs. I have two questions
1. Does each disc take its signal from the hub only or can the discs operate in a chain whereby a disc can take a signal from a nearby disc and so on.
2. Is there a limit on the number of discs that can be supported by the smart hub.
I ask the questions as I'm considering trying to get the WiFi into a static caravan at the bottom of the garden. If the discs cannot operate in a chain I will have to consider WiFi extenders plugged into the ring main.
